Looking for (4) adapters to put on my '91 F250. Wanting to change 8 on 6.5 to 8 n 1760mm, 1.5" wide. Does any one have some used ones or where is the best place for new ones?
I did the same thing. Found mine on Amazon. Keep in mind you will need to trim a little off the studs with the 1.5 adapters. Not a big deal. I think I got the whole set for just under 200.00 delivered
mine came go on with the lug nuts that allow you to mount the adapter . You will have to buy new lug nuts to mount the wheel as the new studs are a different size. I forget what size they are off the top of my head.
Correction, the adapters came with lugnuts that fit the studs on the adapters not on the truck. You have to change those out as well though, depending what wheel you use.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
