New Style Wheels on older truck
mikeboggess
Texas
Looking for (4) adapters to put on my '91 F250. Wanting to change 8 on 6.5 to 8 n 1760mm, 1.5" wide. Does any one have some used ones or where is the best place for new ones?
jwsfarrier
Molalla,OR
I did the same thing. Found mine on Amazon. Keep in mind you will need to trim a little off the studs with the 1.5 adapters. Not a big deal. I think I got the whole set for just under 200.00 delivered
mikeboggess
Texas
Were you able to use the factory (OE) 1 1/16" lug nuts? Will they fit in the recess for the lug nuts? Thanks for the link.
jwsfarrier
Molalla,OR
mine came go on with the lug nuts that allow you to mount the adapter . You will have to buy new lug nuts to mount the wheel as the new studs are a different size. I forget what size they are off the top of my head.
mikeboggess
Texas
They (oe) are 1 1/6", 9/16-18, I believe Dorman makes A 3/4", 9/16-18 lug nut, but the adapters come with 14mm studs right?
jwsfarrier
Molalla,OR
Correction, the adapters came with lugnuts that fit the studs on the adapters not on the truck. You have to change those out as well though, depending what wheel you use.
William88
