I'm no expert, but I don't think that's right. She is running a bit too retarded it seems.
So I set it to about the same distance, but advanced.... and the smoke is gone!
Guys, I cannot believe it was that frigging easy!
I just ordered a water pump (could move the fan side to side and it has a drip), and am going to the parts yard this weekend for all the body parts.
Again, thanks for all the input guys, and a special thanks to Selahdoor!
I didn't even bother with a compression test, and will do one when I eventually put in a new set of injectors.
Good work!
When it's time for the injectors, make sure that you buy from one of the known quality vendors - Wes, Russ, Mel or Justin.
