carid
Supporting Vendor
If you are looking for a solution for a small spacer lift, Supreme Suspensions has everything to help you! This brand is one of the leading manufacturers of leveling kits and components, designed to improve the looks of your truck and install bigger tires.
Each component is CNC machined for precision and accuracy, and then anodize coated to ensure superior protection against rust and corrosion. Designed to provide an OEM quality ride with untouched handling and cornering ability, Supreme Suspensions kits allow you to fit larger tires while giving your truck that aggressive stance.
Supreme Suspensions® - Pro Billet Series Strut Spacer Kit
Supreme Suspensions® - Pro Billet Series Suspension Full Lift Kit
* These kits are good for up to 33" wheels
View all Supreme Suspension lift kit options available for your Chevy/GMC!
https://www.carid.com/supreme-suspensions/
