Tomorrow the truck is going on the dyno, so did a bit of last minute work to get it up to *****. Replaced the leaking champion radiator and changed the oil with the second dose of PDD diesel 15-40w. I also deleted the CDR, and welded in one of my -12 an bungs that I use for my valve covers into the timing gear cover.
I ran an elbow off that and push lock hose straight into the intake, super simple leak free setup.
Did a 0-60 run to get a baseline data point for the dyno tomorrow
I could probably have done a bit better if I repeated it and got less tire spin on the launch, but it’s fairly accurate for how the truck performs in its every day daily driver trim. My goal is to get 300hp out of it tomorrow, I think it’s doable with this setup and a pretty good number for a bone stock 58mm turbo. Just as a recap, all that’s done to the truck currently is:
CDD 130cc db2 (150+cc peak)
Stock injectors that came with the junkyard engine
Head studs torqued to 120 ft lbs (reused from three engines now)
CXRacing 31x12x3 intercooler
Wastegate port deleted with 3” hood stack
Stock idit turbo from the last junkyard engine with plenty of shaft play
Walbro GSL392/ Holley bypass regulator
