Too loud?
Josh Oldenburg
Baileyville IL
What's the best way to quiet down an IDI with out restriction on the exhaust. My 7.3 is currently straight piped and dumps out in front of the rear tire on the passenger side. The noise I hear coming from the exhaust drowns out everything including the rumble of the engine. It's too much to handle. Looking for ideas on non-restrictive mufflers people have success with on the idis. Turbo is in its future
Sent from my Pixel 3 XL using Tapatalk
Oldiron
Florissant, CO
I'm no pro, but ive read that running the 2 pipes from each side into a 3" collector and then 1 single 3" into a straight through muffler works well for sound and performance.
kuskoal
Yokosuka, Japan
Check out the MBRP quiet tone mufflers. I put one on my IDI and jeez, it actually made a difference! I live on top of a hill and this thing is LOUD coming home. Just gotta get to insulating the oil pan now...
frankenwrench
overkill is under rated!
Weatherford tx
The turbo quieted mine down more than any muffler ever did. Do what u wish, but u may have the issue solved already this spring before u drop in necessary cash into an issue that may already be covered in your future plans. Just my opinion.
mexicanjoe
texas
im thinking some smittys glasspacks for mine. That way when my neighbor cranks up the music at night I can crank up old LuLu Belle! Seriously, Im thinking a turbo muffler may be the way to go if I can fined a bolt on unit.
reset2
Myersville MD USA
My son Jon put a 4 inch flowmaster muffler. Then we used a Powerstroke tailpipe 3.5 inch. NA it was much quieter than a faster, but once I turboed it it was perfect. After about 50k miles the muffler went bad. Next up is a 3 inch Flowmaster with the same power stroke tail. Let you know in a couple months.
Sent from my SM-G935V using Tapatalk
compressionignitionrules
Bluevale ON
put both pipes into a 4" nelson straight through short muffler, then worry about where to dump it. No restriction and a lot less noise. had 2.5" straights to shotguns out of my 89 , was way too loud! go to a heavy truck parts place and get them to let you look through the Nelson Catalogue. its there and I got mine for under $100 Canadian about 3 yrs ago. they won't want to order it because they want to sell you what they have in stock. you can turn down it for now and worry about a tail later. have fun
IDIBronco86
Staff online
