milkshake oil after startup
Josh Oldenburg
Baileyville IL
ok so prior to installing my 7.3 in my superduty I rebuilt the oil cooler. I also did a compression check and all cylinders were right around 400. After about 10 minutes of running the engine in chassis the oil has taken on a grayish color almost white. i have seen worse than this before in gassers. There is no missfire and it cranks right up however im concerned about head gaskets or a cracked head/block. There is some oil residue in the surge tank so I am praying I botched the cooler rebuild. Does anyone know if a hydrocarbon test will work on a diesel engine?
Josh Oldenburg
Baileyville IL
my buddy came over and said that im jumping the gun and that if it were a coolant leak that it would be way worse
lotzagoodstuff
Carmel, IN
Just wondering: did you pressure test the oil cooler when you had it off? They can be prone to corroding/pinholing.
Lastly: you said "7.3 in your SuperDuty": is this an IDI or a Powerstroke?
Personally I would do a cheap oil change (tractor supply has 5 gal buckets of 15-40 for just under $50)
Then see if it comes back. You could also pressure check the cooling system. (Drain oil. Leave drain plug out, then check)
Josh Oldenburg
Baileyville IL
This is what I got
Sent from my Pixel 3 XL using Tapatalk
1992 idi 73
Mason ohio
You put and IDI in a SuperDuty,:thumbsup: that is one of the coolest things you could ever do! What year is the truck and picture of the build would be much appreciated.
YJMike92
NW Arkansas
I would check the oil cooler and see if you pinched an o-ring or a problem with cooler itself. I would definitely stop running the engine until you have the problem figured out. coolant in the oil is pretty rough on bearings.
Josh Oldenburg
Baileyville IL
Here are some
Josh Oldenburg
Baileyville IL
Yup only have had 10 minutes of idle time bleeding the system when I found it
Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
OAKHURST CA
An IDI superduty ? Never heard of it, and what yr. truck is it ?
Ive never seen a spout like that on a valve cover.
William88
Staff online
