ISPKI
Hey guys,
my 1994 frankenstein 7.3 N/A IDI is suddenly having severe air intrusion, the return line from the IP to the front right injector was half filled with air and it would not fire up. The shrader valve on the fuel filter head had next to zero pressure in it after cranking it over for a bit and as I watched the return line (mine are clear) good size bubbles were adding to the air pocket.
Seals were new viton orings as of almost 2 years ago.
Something I noticed is that the steel injector line nuts that thread on to the injectors dont even come close to contacting the return line caps and the return line caps are fairly loose. They wont pop off easily but they jostle around quite with my finger and when they do, air bubbles start to fill up the lines rather quickly. It seems to me that they could leak when cranking over the engine.
Is this really how these are designed? Has anyone tried putting a washer or spacer between the return line caps and the injector nuts to try and get the caps to seat better?
