I bet it wouldn't have passed an inspection either. That is if they look at things like that.Well.... I guess it technically did work lol!
Compression fittings on brake lines will cause a failed inspection in PA . Happened to me years ago when I didnt know any better
According to the invoice ( under future work needed) it says compression fittings....so I guess the previous inspection was a lick it and stick it joint....yeeesh. Can these be replaced with another type of fitting or am I looking at a big buck fix?
Before I got my dually I had a front brake line on a S10 repaired with compression fittings. That was back in early 2000's. Passed PA inspections in York county every year.
I say if you are going to pull a trailer, just replace the brake line and be safe. What part of PA you in?
What do you use to haul your dead quarter horse?This truck is only used to haul my living quarter horse trailer.
A compression fitting can be replaced by changing the brake line or by removing the compression fitting and installing a flared fitting (requires a flaring tool) and a union to replace the compression fitting. Any auto repair place can easily do this should not be that much money as long as the brake lines are decent
