david85
Crikey! That's some screw
You know, there's SOOOO many things that I'd like to say in response to that, but I have to keep it family friendly so I can't!Crikey! That's some screw
Here is my retorque scenario:
100 garbage trucks out the gate daily.
Corporate policy wheels must be retorqued after min 8 hrs running. With hand torque wrench 500 ft lbs. Everything has to be tracked on paper.
Since most trash trucks have 4 axles, that is 800 wheel positions. 1,200 tires. About 8 flats per day and average tire life 6 to 9 months for wear. With all this torqing going on at least I learned some things. Most wheels were at 1,000 ft lbs, 2x the spec. Stripped studs and snapped studs reduced to nearly zero after the program. Reforques found at least a few nuts loose daily. The most important factors: clean hubs and wheels are critical. Most common cause of loose wheels.
There is a 59 GMC that was once in my fleet that I kept “hid”. Ended up restored in a garbage truck museum in Florida.Would love to get a old school trash truck or just even the shell
As long as they fit a 16" rim itll work fine... leave the 10 plys up front and the 4 plys over the empty rear end. Almost 4,000lbs over a 4x4 IDI front axle!Random question on tires since I'm in a pinch and just need to just move my truck home for minor repairs/no more ex gf parents rant about my truck in her drive way with two blown tires can I use 4 ply instead of the normal 10 or 12 ply tires, I still have the original rims just can't afford $500 for tires right now and seeing as Walmart sells only 4 ply thought it might work.
This is better advice! ^^^^^^The_Josh_Bear is right but I would call around near you. Actual tire shops usually sell used tires (with limited availability) and they may have some 10 ply tires. They wouldn't be new but there's usually a substantial cost difference. If our local store has them they're usually around $35 for a year or so worth of tread. That's not great, but those 4ply tires are pretty squirrely when you're used to 10 ply.
Tell them your situation, a good tire shop will know what sizes are close enough to work and they might have a pair that's close if they don't have the right size. ( ie 235/85/16 and 265/75/16 are very similar in diameter)
I gave up "gorilla torquing my lug nuts with a "T" wrench, years ago.
Took the car in to Sears, to have new tires put on, and they came back and said they were going to have to torch all my wheel studs off, to get the wheels off.
I walked out there and popped a tire completely loose with the t wrench. Just to emphasize the point... Put it back on. And drove away without buying the tires.
