10 lug front axles
edpruss
Longmont/CO
Keep in mind, if some kind of wheel adapters are used on a steering axle, the wheel will move out the thickness of the adapter, thus making less ease of steering, more wear on bearings, etc. centerpoint steering being the goal.
hate to hijack this thread, but where have you seen the 8 bolt to 10 bolt adapters for the front end? on a D60 frt end. I'm wanting to do the same thing and can't find the adapter.
giezy
rockwood/on/Canada
Doesn't the front on a 2wd f450 have the 8-10 adapters? The p30 chevy has them they just need the other five holes drilled and the hub opened a bit
JMurray
SWMO
If you could find one from a F550 it would be a super 60 heavier u joints, 10 lug, tighter turning radius lots of gear options compared to the big stuff.
thedieselkid
westva
old thread but there is no factory 8 to ten lug adapters. 99-04 8x170 to 8x226
05 up it 10 lug to 10 lug adapters 10x225.
William88
Staff online
