Intermittent "engine"light
Diesel8873ne
Mass
88 f250hd 2wd 7.3 w/zf5 and banks turbo
Recently after my turbo install the "engine" light will come on sometimes on startup sometimes for no reason driving down the road. And most of the time it goes out on its own or on a downshift.
The oil pressure sensor is relocated to the oil feed side of turbo.
I figured its a bad sensor just dont know the location or what else it might be.
bbjordan
Snow Monkey
Ashern Manitoba
It could be a poor connection on the oil pressure sensor. It could be a poorly grounded ops too. Did you use teflon tape on the ops or the ground path for the ops?
Diesel8873ne
Mass
Ops is from the po of the turbo left it in the feed side and just plugged my wire in. Not sure where it grounds.
My ops broke into pieces when i took it off the truck
fraree
Inland. Australia
I have a similar question, my orange "engine" light has stayed illuminated since all my work was completed. What connection or sensor should I look for ?
My speedo reads in kilometres per hour too ;)
Oil pressure sensor. You can get it at any parts store, motorcraft is always best.
fraree
Inland. Australia
Thanks, now I know where to look ! Nothing much for these trucks is readily available here in Australia & anything which is, is 3 times what it's worth.:eek: Currently our exchange rate is .69 USD cost us $1Au :oops:
Cubey
Van dweller
My F250 does it. It's directly related to the worthless factory oil pressure gauge in my case. At idle, if the gauge drops to or below the left side line, ENGINE comes on. The gauge waves around there at idle when at full operating temperature, making the light come and go. It has a mechanical oil pressure gauge which reads normally, so I just ignore the engine light. That's why a previous owner put the oil pressure gauge, the factory gauge made them think it had a problem.
fraree
Inland. Australia
OPS out here $115Au
Spent the money, fitted up the new sensor, light is still on. :eek::(
Put the code reader through the system, only code which came up P0237, something to do with the turbo "Turbo boost sensor A circuit Low Input" :dunno
If you can read obd2 codes you don’t have an idi, you have a powerstroke which is a completely different setup.
Ramtough01
