1st gen cummins oil burner.
Joe Blow
Ragley
what are some of you 1st gen cummins oil burning guys using as electric lift pumps. thanks
dieselfollower
Brevard, NC
Totally not what you asked for, but I run a mechanical 12 psi piston pump from THD. Got 150 gallons of WMO but have only run a whopping 5 gal. so far
RetiringColt
Washougal WA.
I have a 90 W250 and also run THD low pressure piston lift pump. I run a Larry B's liquid filled pressure gauge on the end of the banjo bolt after filter. Gives me some insight into how the filter is doing. I probably have somewhere around 30-50k miles and no issues. I preferred to keep as much as I can mechanical. The hungry diesel sells as a complete kit. The only thing extra I had to buy was a 90° hose barb fitting for the rubber line to the pump.
u2slow
bilge rat
PNW
Not going electric.
Running stock diaphragm at the moment with a water separator (Racor copy) on the suction side.
Intend to go with the piston pump style when I revamp the fuel system. I have a NIB Carter 2ndgen pump I'm going to re-spring for lower pressure.
