Waking up my 7.3
culver21
Michigan
my truck has been parked all winter and it’s getting about that time of year where I live to get it out and running as warmer weather is coming. Is there anything I should do fuel wise for it before trying to start it. It was parked with a little less that half a tank with some anti gel fuel additive in it.
culver21
Michigan
I sure hope it does. I wasn’t sure if there would be any moisture in the fuel or anything.
RetiringColt
Washougal WA.
X2 on checking fluids. Maybe check your batteries and little slow charge for a few hours. I like to do a 2 amp charge for the better part of a day.
Checking fluids and a trickle charger is a great way to get going safely. If your fuel system is tight, No leaks... It will fire right up. My rig sits for a couple of months and never fails to fire up with no long cranking ever.My fuel system is leak free and tight..
William88
