Pensacola diesel?
Golden Helmet
Monterey County, California
What about a bostech from fordiesel
Never heard of them, and there's probably a good reason for that ;)
I know that pumps from the good sources aren't cheap, but you're better off pouring water on an old IP and saving up for a good pump than you are spending money on a no-name / ebay pump. If you do go the no-name route, 9 times out of 10 you'll get a piece of garbage and you'll have to spend money again to get a pump from one of the good guys, or sell the truck out of frustration because "for some reason" it just won't work right.
jwsfarrier
Molalla,OR
spend a little extra money now and fix it once . You will not be disappointed with any of the previously mentioned vendors! Pensacola is darn sure not one of them
Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
OAKHURST CA
Just sent my PENSACOLA Injection lines to get powder coated ! Yikes I hope they will be ok and not leak.
chillman88
Central NY
They probably source their lines from the same place as everyone else. The labor/service is the problem everyone has with them. Its the difference between a good shop that you go in for a water pump and they fix it right vs the shop that tells you it's leaking, says he replaced it and only flushes the coolant because he needed the money.
papadiesel
Indianola, IA
lines should be fine, only two companies make them outside of custom, International and I forget the aftermarket one. Tim at Accurate diesel sells the set and individual for a fair price as well.
