FordGuy100
Nope, just wastegate unhooked. To be fair I couldn't tell you what it is above 15 psi since my boost gauge is 0-15. But considering where the needle lands I'd wager upper teens low 20's.
You didn't have to re-stud the heads on it? My truck is all stock. I just really don't want to over-boost and grenade the motorI run 15+ also but not all that often for years now with no blown gaskets yet, but not really stock anymore. R and d 90cc, stage 1’s, carter 4070, “factory” turbo with banks compressor housing and 60-1 mod with ats 093 hotside. 10psi is just about instant even with intercooler
You won't grenade the motor. Worst case, you'll blow the head gaskets and have them start to leak combustion gasses into the coolant.You didn't have to re-stud the heads on it? My truck is all stock. I just really don't want to over-boost and grenade the motor
just a thought, have you tried flack jackets?I just want a bullittproff idi .
directly or indirectly? say when!I WILL return fire
1 is doneYep
We should hook up.
You get the flatty ready for spring?
That's not an oil leak. It's rust proofing!2 needs intake gaskets to cure a very minor oil leak.
