So I have run out of fuel a few times at a 1/4 tank, and PO said fsv doesn't work. So I get new shower head and plan to do the fix, its a flat bed so takes more time to get boards off bed then to swap part out.
Much to my surprise the shower head is intact except for the small rubber check valve in the side of unit, its at the bottom of tank so replace head anyways, obviously with the valve out its sucks fuel thru this opening first, acting like a broken off shower head, I was suspicious because the PO had replaced the tank, and figured the shower head sender would not be original and newer.
So on to the rear plastic tank, pull it dump 10 gallons of very old diesel 5+ years out into buckets, and find nasty sludge and broken, (sure original shower head). Now some questions,
1. Is rear sending unit same as front? for I already put front tank unit back in, looked similar.
2. Best solvent /fuel to clean rear tank?
3. Plan to disassemble FSV and clean, heard here it can be done.
4. Now I will use old shower head in rear tank and secure check valve better.
Rear tank mess, almost turning back into crude oil,tar!
Inside tank pic, shower head remains!
,Rear tank mess, almost turning back into crude oil,tar!
,Inside tank pic, shower head remains!
