Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
so I am looking to get a new Injector Pump now that ai found out mine is leaking.
I have had the turbo rebuilt and ceramic coated and should put out at least 15 lbs of boost.
I have installed R&D Stage 1 Injectors and R&D Fuel Rails and and the R& D air cleaner kit.
R&as does not have the pump I want the RD2-90, so I am looking at the Ford Bull Moose DB2 Pump.... the recommendation is that I use it with an inner cooler.
So question 1. Can I install this pump and use it until I get an inner cooler installed ?
2. Is the inner cooler absolutely necessary and why ?
3. Any other recommendations on good heavy duty IPs that can withstand running on veggie oil ?
