Christian9112
I have a 7.3 IDI and about 5 gallons of old brake fluid. It's essentially hydraulic fluid with anti corrosion additives in them right? Master cylinder has rubber seals and they never rot out. I'm doing some research and it says that dot 3 is required to not break down any seals or corrode any parts of the braking system. Just not sure how well it would burn.
