The best option is to eliminate the two piece design and use a spin on fuel filter that has the drain built into it, this will work but there’s cheaper options out there if you shop around.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
