The lines are 3/16. The fitting sizes are anybodies guess. Many possible combinations. Look at your rear line back to the rear brake hose too. They love to rust in two, right behind the cab.
Replaced rusty straight pipe with 3” exhaust.
Still have a leak to chase up near the turbo.
This week - changed oil with 10-40 delo
Topped off rear diff... took 2.5 quarts lol
Changed fluid in ZF5 with mercron V
Topped up front diff and xfer case
Front and rear diff are getting geared to 3.55 at some time soon. Found a shop to do the rear for $800 and the front I’m going to buy a used 3.55 axle, replace the balljoints/ujoints and seals and bolt it on
New wheels and tires. The wheels are 16x7 AR Outlaw II with a 3.7” backspace. Tires are 265/75/16 Corsa Highway Terrain. I usually buy name brand tires but these were only $92 each so I figured what the heck. They are E rated.
