Riphip, thanks for the response.
SB308s are not the correct bushing for any of the rear suspension.
I don't have the numbers on me, but I went with a new Dorman shackle/bushing combo, which left pressing bushings only into the leafsprings.
I unshackled them and used my 20 ton press, it worked a treat. The rear end is completely tied down now, brakes bled.
A couple of issues:
The turbo leaks oil, and appears to badly. Tips, suggestions? It also seems to leak exhaust when the throttle is snapped, from behind the turbo.
There is also what appears to be oil coming directly out of the exhaust. Subtle white smoke on idle, although there is definitely air intrusion so I'm not as concerned about that yet.
The #7 injector return line WILL NOT SEAL... new o-rings, new tee, assembled with silicon paste... twice... still leaks! ***? Fuel isn't coming up from the injector, but from the Tee.
Thanks all for your time and wisdom!
