What the.....
leftcoastjeff
Frankentruck lover
Monterey, California
After moving my truck up the dirt driveway my roommate found this interesting bolt left in my path
Haven’t had an opportunity to clime under and see ***.
Do you recognize this?
OBTW just had major trans/transfer case work done recently by someone I trust implicitly
Leftcoastjeff
Man I know that bolt. It’s a very specific use, maybe tc shift linkage bracket? I’ll think of it in a bit I’m sure
Clb
Another old truck
nannyfornia
Pulley bolt?
Yea it's a special purpose fer sure.
I think shift linkage has a bigger hex, plus has a torx in the middle.
I would look at the crank pulley.
Sent from my SAMSUNG-SM-G930A using Tapatalk
leftcoastjeff
Frankentruck lover
Looks like a Toyota crank pulley bolt.
that is a harmonic balancer pulley bolt for a japanese built motor.
Wow you guys are good
Just ran out and sure enough the Toyota is missing the harmonic balancer bolt but seems to be on tight!
Glad I asked, hate for that to fall off
At highway speed, no telling the damage that could do
Best regards,
Leftcoastjeff
Best regards,
Leftcoastjeff
that would have really ****** up your day.
btw. thanks for the vote of confidence on the transmission and transfercase work :D
Cubey
Van dweller
It's amazinghow lucky things don't fall off. I went to do an oil change on my mom's car once, a 2003 Taurus, where the oil filter is up near the radiator. I reached down and bumped it with my oily thumb (from doing the drain) and the filter turned!! It wasn't tight in the least!! I guess the oil pump pressure kept it on? Or just pure luck. She had it done at a midas that last time.
William88
