renjaminfrankln
What does this connector on the IP do? A google search and a review of a few tech threads did not answer. There is nothing hooked up to it.
I have an 89' 7.3 with banks turbo kit.
Also dealing with an air leak. One of the injectors is obviously leaking. It will leak down in the span of 10 minutes and run rough after start. Sitting overnight and its real tough to get going. The fuel heater is not leaking.
The previous owner did the return lines so I don't think i'm going to go in wholesale and replace all of them. Another injector or two might have a leak as well but it could just be this one. What is a safe solvent to clean these up with so I can figure out which are leaking? Hit it with a little carb clean? non-chlorinated brake cleaner?
