Wtb. - 1ton front springs/rear lift blocks
ShadetreeV
Redding
Needing a set of springs for the d60 setup ony 94 f250. . .looking for the rear lift blocks as well
Located near Redding CA.
kcwright1979
Redding Ca
Pick n pull has a 93 f250 diesel with the springs under it as of today. It has an IFS axle but I believe the springs are the same. They are having a 40% off sale all this weekend for club members.
ShadetreeV
Redding
Good looking out guys i appreciate you all chiming in. Looks like I may be needing to find a new set or hold out until pick and pull gets an f350 in
ISPKI
Granby CT
I just swapped front springs from an OBS F350 7.3 into my 94 F250 7.3. F350 had a D60, mine has the TTB. F350 springs swapped right in. Not sure what is different except that the F350 only has 2 leaves and mine had 3.
VWAudiFord
