X Code Front Springs Installed
dakotajeep
Patrolling
TN/ND
For those that want an inch or so of lift or more capacity to offset the weight of a winch or plow.
You can get the Ford factory X-Code springs which come standard on the 450 and 550. This wont work for the 05 or newer since they have the coil springs up front.
If you are curious about part numbers let me know or just call your local Ford parts guy. Although, mine told me that it wouldnt lift my truck which it did.....
Before:
Immediately After:
A few hundred miles and the topper removed:
If you are going for more of a leveled look this is not what you are looking for....
Sor far it looks as though I have gained just over and inch of lift after the initial settling. I havent noticed much of a difference in ride quality but I hadnt been driving the rig for 8 minths due to a deployment....
Thad
