well if it were me I would drive and enjoy but that's just me... When she gets to hurt'n she'll let you know.
To be able to tell which bearing - it's a crap shoot - your guess as good as mine.
I like your math better - let's go with it...
Ok so the bypass is new so that takes a plugged filter out of the mix if you ask me. Now what you might try doing is dropping the full flow filter at around 3k but keeping the same oil and bypass filter.
I got this idea because before I had the bypass set up installed if I ran her for anywhere between about 3.5~4k between oil and filter changes the full flow would plug up and I would have zero oil pressure at idle but would have good oil pressure at off idle conditions. I found that through sampling that I could just swap the filter and go because the oil was still good (TBN test) just the filter would catch all the junk causing it to clogg and go to a bypass situation (unfiltered oil in engine). So it might be as simple as that... It's worth a try.
did you change the oil and filter this time around? or did you just take a sample?
