Somebody will happen along with the right info purty quick here,
GEO!!!!!!!!!!!!!!!!!!!
Easy there Mike................... You guys are handeling it as well as I could
Billy, You have two choices....a swap to an E4OD or a Gearvendors auxillary O/D unit.
It will be about the same $$$$$$$ either way.
You can buy used Gear Vendor units just as easy as you can buy used E4OD's.
The swap to E4OD is as straightforeward as it gets.....
you just need from a boneyard-TPS,PCM, shifter colum.
You will need a tranny temp guage, HEAVY DUTY cooler {do NOT use the radiator} and some drive shaft work as the E4OD is quite longer than a C6.
The real choice on your part is WHICH E4OD to get....Suncoast, Jasper, BTS{if I were an auto guy, BTS would get my $} or find a decent take out/used one and take your chances.
The Gear Vendor unit will require drive shaft work as well, but only the wiring of a switch.
Hope this helps
GEO
