No. I'm not complaining about them.
I'm asking them!!
89 f250 7.3idi no turbo.
I've heard about the antifreeze being a special kind. Or maybe some kind of additive? And then testing, to see if it is correct?
Can someone explain that to me?
Next... My heater is always on. Means it gets pretty hot in the truck, when the outside temp gets above 40. Especially bad to go through a summer like that.
Instead of digging around under the dash, and pulling it all out to R&R... I think for now, I want to just put a shutoff in the hose going to the heater core.
I bought a brass/bronze/stainless ball valve that I think will fit in the hose pretty nicely. There is already a 'flush kit' adapter in one hose. The thing you connect a garden hose to, to do a flush of the cooling system. For the moment I am just going to assume that that was put into the correct hose.
My question is, if I remove that adapter, and put the ball valve in it's place. Then close the valve to turn off the flow of water...
Am I taking any chances with breaking something?
Thank you.
I'm asking them!!
Thank you.
