Stock Air Filters
jlayne
Bondo Bandito
Milledgeville, GA
keeping your warranty in force.
changing filter manufacturers will not void a warranty since the Magnuson-Moss Act
read Tie-In Sales section
pick the one thats a brand of your choice from where ever you want to buy it and run it... your not going to void your warranty as long as its a drop in "stock replacement" type filter... a high flow intake might cause a fuss... not just the filter
Mike
Stroker
Cora
RKOCH said:
Why not use a K&N and never buy a filter again? I will not use a paper filter in anything.
I'm just the opposite, after switching to a big open element paper filter I will never use a K&N again.
ISurvivedNMU
Michigan
Airraid has a syn filter that goes in place of the stiocker... And its the right price... I would do that... K&N relies on a oil to catch dirt... Others use media..
jlayne
Bondo Bandito
Milledgeville, GA
same here... i have reverted back to using a stock paper filter (till i get a tymar) after using the drop in k&n... no noticable loss in power, increase in EGT, decrease in milleage
the only thing that changes is that the dirt that the K&N was missing that i noticed in my intake hose is gone... to each his own but they let to much junk by for me
ISurvivedNMU
Michigan
Most of the problems with these reuseable filters is that they are oiled to much... If they have too much oil, your diesel will suck the stuff through the filter since its breathing capabilities are hindered by the oil....
I have a hard time with this, since you really want to oil the filter up when you clean it.. not a good thing... Thats why I go with a better filter that uses more than just oil and foam to catch dirt...
rgdillon
Junior Newbie
Virginia
Personally I can't find anything wrong with the stock Donaldson filter. I have zero plans of changing to anything else.
I would like to "try" some of the other "top" brands - hook up the AutoEnginuity and take readings from the sensors comparing them to the stock.
Ron
jlayne
Bondo Bandito
Milledgeville, GA
RKOCH said:
How do they let to much junk by when they are garanteed to give the best filtration?
like i said to each his own but they let dirt by on my truck, you could litteraly see it in the intake tube and i had the gasket sealed with grease so it had to come through the filter
it also correlates with what this guy said in his research
some people like them, i'm not one of them
the only answer i can give you on the garantee is that if i crap in a box i can garantee it to do anything and some will swear that it does if marketed correctly... but that doesn't mean it actually does
yes the K&N probably does give you a hp. or 2 at WOT but to me the lower leval of filtration is just not worth it... it also seem counter procuction on a truck that we are all trying to get oil out of the intake by ccv mods and so on to just reintroduce it in the form of mist coming out of the air filter
it also depends on how long you keep your truck.. if you trade every few years then a k&n will most likely cause any wear on your truck but if you are like me and keep them untill it is totally worn out, i like to keep it alive as long as possible
RKOCH
Fellow Oil Burner
Yorktown, Virginia
I have 475 K on my 88 7.3L work truck and I run the **** out of it. I have always used a K&N on it oiled it correctly and used Amsoil and their filters with their by pass system. I have so little blow by it is really hard to see and almost zero smoke except when you start it till the cyl temps come up to completely burn the fuel. I put the turbo on it with 200 K and have never noticed any dirt in my air intake system. I think it goes to how you maintain you $hit. Plus a little oil in the intake from the filter aint hurting nothing thats just more fuel to burn. ;)
tgatch
You are probably right, but I do know that GM has a TSB telling the GM mechanics to remove a K&N if found and replace with a Delco filter if trouble shooting intake issues. Most people over oil causing their own issues. But I have also seen an independent study that shows that K&N Loses filtration capability for every washing.
It is a personal choice. I know that I had build up in the throttle body of my 97 Wrangler with a K&N. After seeing the study I pulled it from my Jeep and my F150. I will stick with my Ford/Donaldson/Wix filters. I've got almost 30K on my original one and all seems well. If I get 40 to 60K out of it, I think I can cough up $40 for that.
Ramtough01
