>>> SLEEPER BOOT <<<
Discussion in 'Lounge' started by MIDNIGHT RIDER, Jul 14, 2012.
  1. MIDNIGHT RIDER
    MIDNIGHT RIDER Full Access Member
    4,580
    Sep 29, 2005
    I have just spent the better part of two hours searching for something I figured would be a simple find --- replacement sleeper-boot material; comes in a roll and sold by the foot.
    I can find that accordian stuff everywhere, but not the big truck stuff, which is simply flat, with no edge-clips nor pleats.
    My sleeper is a Double Eagle; I tried my links to their site and only get "this site no longer available", like maybe they are no longer in existence. :dunno
    I figured I could have found this stuff, had it bought, and already been in bed by now.
    Does anyone know of an online source for sleeper boot material ??
    I have found a few places that advertise replacing sleeper boots, but their sites are very spartan and only say that they do the service.
    Thanks.
  2. gandalf
    gandalf Senior Member
    2,826
    40
    Jan 21, 2005
    CA
    There's a possible answer, or at least a hint toward an answer, at the following website.
    Double Eagle
    They mention a phone number and a website address. Hope this helps.
  3. RLDSL
    RLDSL Diesel fuel abuser
    7,701
    Dec 14, 2005
    Arkansas
    THe company is out of business. Too dang bad, I would love to have one of those things.
    Id bet they are attached just likea big truck and they use a big strip of flat heavy rubber pinched into the framework on each side
  4. MIDNIGHT RIDER
    4,580
    Sep 29, 2005
    It is just like you describe, RSDSL.
    There is a panel screw-attached onto the back of the truck's cab that has a flange that is an exact match in shape/size to the opening on the sleeper.
    Onto these flat flanges, both truck-cab and sleeper, first = an inch-wide strip of gooey tar-like sealer goes all the way around; on top of that, the actual flat rubber strip of boot that spans the gap between cab and sleeper; another layer of that gooey stuff; over all of this are two flanges that clamp/sandwich all of this together, through which a million screws clamp this flange to the ones rigidly attached to the cab and sleeper.
    The butt-ends of the wide rubber boot meet at bottom-center where it is least likely that water will ever intrude.
    Once all of this is installed and firmly sandwiched together, a thick layer of cushioning foam goes all around, covered by a leather upholstery and various trim pieces to yield a finished look.
    It takes a good day to get at and replace a boot. :)
  5. tonkadoctor
    tonkadoctor Full Access Member
    3,776
    May 5, 2006
    none ya bidnes
    Check out the products from Uni-Grip. They have all kinds of rubber extrusions.
    I've bought accordion seal here and can highly recommend them.
    They are a manufacturer that sells direct to the public and will cut you any length you need.
  6. MIDNIGHT RIDER
    4,580
    Sep 29, 2005
    Thank you, tonkadoctor; I will give them a call as soon as I get some accurate measurements.
    As hard as this stuff is to find, I will probably get enough for two or three re-seals. :)
  7. Hoss6.9
    Hoss6.9 V - "The BOSS"
    50
    531
    Jan 8, 2005
    Mongo, IN.
    Hey Rider! I am about 20 miles from Shipshewana. Where Double Eagle or (Double Buzzard) as we called them from where the shop was. They have been out of business for quite a number of years. ARI - Legacy Sleepers is in Shipshewana also. They build the best sleeper on the market today. I have a friend that works over there.
    Link to their site: http://www.legacysleepers.com/
    Maybe they can help you out too.... They are good people to deal with....
    Let me know if I can help ya out....
    Hoss....
Share This Page
