Mikes91
Since I've owned the truck, I've noticed a shake while the truck is idling.
New lines, caps, and injectors when the turbo went on in 2003 didn't solve the problem.
Any idea why the truck would do this? The Ford mechanic who looked it over a few weeks ago didn't feel it was a significant issue... but I wish I knew what it was.
I've not done a compression check... don't have the time and tools to do it myself... don't want to pay Ford to do it.
The shake is especially visible if I open a door while the truck is running and parked... door moves up/down about half an inch.
Idling up just a bit seems to help just a little bit. idle is about 700-750 right now... so a bit higher than spec.
ON EDIT: This shake does not occur regularly during the idle process... not necessarily equal time intervals between each shake.
Thanks,
Mike
Thanks,
Mike
