So I had a spare mechanical temp gauge laying around and was curious after a long trip of how much my oil going through my 12 feet of braided hose was cooling off by the time it re enters the engine at the filler neck.
On the output side of my filter base I put a T and faced top of the T to the bottom so the oil would have to go over the sender as it passed through the T and hooked everything back up. Even today in mid 60's weather after an hour of driving through the hills, the oil is here:
160 doesn't seem too bad. I don't know what the regular oil is, but water temp at the overtemp sender port is 185 at the same time. I got a gauge with a longer sender so I can move it over to where I can actually see it by my other gauges. I might keep a gauge like this in the truck (though that will be 6 gauges now, getting crowded)
Just figured I'd post it up in case anyone found it interesting. I can post a picture of the bypass system and how it's routed (poorly) if anyone wants to see. Neat second function of a bypass system though. Mine just doesn't flow crazy fast cause I put a .045 (or .45?) turbo oil line restrictor in it to make sure my main oil pressure stays the same.
I guess it would be more factual if I knew what the temp of the oil in the pan was, but I don't have room for 7 gauges lol
