http://cgi.ebay.com/ebaymotors/ws/e...90306980123&ssPageName=ADME:B:WNA:MOTORS:1123
This is well worth having in your tool box. Its a tool that is needed once and nothing else will do the job it does. It works by threading into the injector hole in the head. Then you ever so slightly mill out the built up carbon that has gotten past the copper gasket on the injector. Don't think you can mill done the cast iron seat in the head because this tool is designed for just "cleaning up" that seating area. Yes, it will cut the cast iron if you have a cut in the seat but don't think you can do it with any pressision depth like sinking all the injectors the 60 thousands that international raised them out of the precups for emmissions testing...
