Rotella vs Delo
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Diesel Max, Oct 12, 2009.
  1. Diesel Max
    Diesel Max 93 F-250 4X4 - 7.3
    518
    Aug 14, 2009
    New Mexico
    What are the opinions on Rotella and Delo for the 7.3 ? Is one better then the other ?
  2. Feed Bunk
    Feed Bunk Cow hand
    80
    Feb 8, 2009
    NW Missouri
    People seem to have good luck with either. I personally dont like rotella. It seemed like our engines smelled like hot burning oil at idle when we used to run it. Delvac or Delo are my pics.
  3. dyoung14
    dyoung14 Is getting worn out
    6,128
    Jan 2, 2009
    spencer,tn
    i have used them all, but i just use rotella cause its very readily found around here
  4. reklund
    reklund Full Access Member
    1,227
    8
    Oct 20, 2005
    Henderson, Nevada
    I like Delo better myself, but have run both. My truck seems to smoke a little differently when using the Rotella, but it never seems to use much, if any.
    Ryan
  5. Diesel Max
    518
    Aug 14, 2009
    New Mexico
    Ryan,
    Does your truck smoke more on Rotella or Delo ?
  6. sle2115
    sle2115 NRA LIFE MEMBER Staff Member
    49
    7,147
    Dec 3, 2005
    Southeast Ohio
    Delo, my truck used some Rotella, doesn't Delo
  7. icanfixall
    icanfixall Official GMM hand model
    24,892
    81
    Delo 400 15w40 oil and no problems ever. I haven't run any of the others. Years ago before I knew there was diesel oil I ran whatever was on sale. It all ran fine and I got 285 or 385 thousands miles on that motor.
  8. 02AutoWag
    02AutoWag Registered User
    165
    May 9, 2008
    Vacaville, CA
    Where does Mobil Delvac 1300 Super 15W40 fit into this mix?
    The previous owner had put 240,000 miles on the motor with Delo 400. Now that I've got the truck, I found Delvac 1300 at a great price... Buy 1 Get 1 Free...$13/gallon regular price---> now becomes $6.50/gallon (Kragen Auto Parts). By comparison, the Delo400 runs just over $10/gallon (Costco).
  9. RLDSL
    RLDSL Diesel fuel abuser
    7,701
    Dec 14, 2005
    Arkansas
    My personal experience from years in a big truck on the road I found they all ate rotella at a faster rate than delo( I had one old Cat that would simply inhale rotella) turns out that later my observations were backed up by numerous independent volitility tests that showed rotella burning off at a faster rate than delo in the lab as well. Delvac fell somewhere in between
    Rotella has more detergents in it than the others do. The odd engine seems to like that, but usually only in colder climates, but in most cases, the thinned out oil just burns faster.
  10. ameristar1
    ameristar1 The One Blue Thing
    997
    May 7, 2009
    Steger, Illinois
    I can back you up on that. I ran Rotella and both trucks that I ran OTR with had consumption issues. Doped it up with either Pro Blend or Lucas and it helped out.
    I have heard nothing but good about Delo.;Sweet
  11. towcat
    towcat Administrator Staff Member
    17,003
    117
    guys-
    do keep in mind both formulations have drastically changed with the new oil specs. none of it is close to what it was 10 years ago.
  12. f-two-fiddy
    f-two-fiddy Registered User
    53
    2,954
    Mar 22, 2004
    Duluth, Mn.
    I dunno, My 85 eats delo at a 2:1 rate over Rotella.
    I think Ya run what got ya there.
    If the PO used Delo, Use Delo. If They used Rotella, use that.
  13. NapaBavarian
    NapaBavarian Dually driver 6.9
    38
    2,011
    Jun 18, 2005
    Napa CA
    It seems more important that you change your oil regularly and check it whenever you fuel up than what you use, that being said, in my cheapie beater car I made 2-3 oil changes with the cheapie "super tech" oil because...it was a beater, soon enough I got a fabulous rear main seal leak :puke: just a little drip, but I don't tolerate vehicles that pull that kind of stunt, good news is that 2000 miles on Rotella and some snake oil and that leak is going away ;Sweet or gone.
  14. Diesel Max
    518
    Aug 14, 2009
    New Mexico
    What kind of snake oil ?? Auto-Rx ???
  15. NapaBavarian
    38
    2,011
    Jun 18, 2005
    Napa CA
    the stuff that claims to cure rear main seal leaks, this car has a rope seal, when the rain goes away I'll find the bottle
Share This Page
