HF has the fan clutch tools for removal. It's a left hand thread, turn it on Clockwise to remove it.
I highly recommend this wrench set that you can use with an air hammer. It's worth every penny. https://www.amazon.com/dp/B000JFJLTC/ref=cm_sw_r_cp_ep_dp_1URZybEPGS7JT
We used RTV with the gasket, do we need to let sit or is it ok to run?
I used rtvFunny...not 1 recomendation for rtv....perhaps because it can mess up the oil cooler bad?
The ****** berries can break off inside and clog the oil cooler tubs thus effectively making it useless.
JM7.3CW
