Recall notice
Discussion in '6.9L IH & 7.3L IDI Diesels' started by motox tech, Nov 15, 2009.
  1. motox tech
    motox tech Full Access Member
    506
    Aug 5, 2009
    granby, co
    I got a recall notice in the mail yesterday, Its for the speed control deactivation switch. Apparently brake fluid is leaking out and causing fires.:eek::eek: Has anyone else got this notice? Its kinda weird, there gonna replace a part on a 15 year old truck.:dunno Oh well, its on their dime, and maybe my cruise will work when they repace it. (just wish there was an autorized dealer less than 80 miles away)
  2. powerhungry07
    powerhungry07 Registered User
    37
    Nov 10, 2009
    lancaster/ohio
    ah yup
    yes i recieved the same letter a week ago ive never had any problems so oh well like you said their dime;Sweet
  3. punkmechanic
    punkmechanic diesel tech
    765
    Jun 5, 2008
    North East Portland Or
    It takes about 30 seconds to put in. no big deal. Basically the pressure sensor in the end of the master cylinder (or down in the proportioning valve in a few vehicles) has a full time hot lead into it. The switch is used to shut off the cruise in the event your brake light switch fails (redundant system). The full time hot lead can short if the sensor leaks internally, causing brake fluid to short in the connector and then in turn ignite. The recall is a fused harnass so as to keep the circuit from starting a fire if the sensor should leak. If your sensor is already leaking then they replace that too. I had one that had a leaking sensor that was seized and destroyed the threads, thereby getting that customer a master cylinder and brake bleed as well (took much longer than the 30 seconds mentioned above).
    call and make an appointment at the local stealership and they will check your sensor and put the fused jumper harness in, all it costs you is time. An appointment will limit the amout of time you wait.
    punk
  4. Exekiel69
    Exekiel69 Registered User
    5,381
    Jul 6, 2005
    Do You have a part # for this? is it for all years 83-94?
    Thank You.
  5. RLDSL
    RLDSL Diesel fuel abuser
    7,701
    Dec 14, 2005
    Arkansas
    Just how are they going about finding all the owners of these old vehicles if they are not the original owners. Are they gleaning the state registration records or what? Curious since mine seems to fall within the effected year span but I haven't received anything.
  6. motox tech
    506
    Aug 5, 2009
    granby, co
    Im not sure how theyre going about it, but I am definately not the origional owner of mine. The letter states that if you get the notice and you no longer own the truck, to please forward it to the previous owner.
  7. maddenji
    maddenji Registered User
    45
    Oct 31, 2009
    Burlington,MI
    I got mine yesterday. I'm the second owner, so they are checking state databases.
    A friend of mine lost his van and garage because of this. If you don't have it done, Ford will not take responsibility for your damages. CYA.
    Jim
  8. RLDSL
    7,701
    Dec 14, 2005
    Arkansas
    What kind of envelope does it come in so I don't mistakenly pitch it along with the daily mounds of junk mail?
  9. lotzagoodstuff
    lotzagoodstuff Supporting Member Supporting Member
    1,900
    May 19, 2007
    Roscoe, IL
    You won't miss the envelope: it's marked pretty clearly as a Ford Motor Company recall. I was pretty shocked when I opened mine as I thought it would be a recall on my 2007 Ford 500 company car.
  10. HammerDown
    HammerDown Full Access Member
    1,897
    Glenolden Pa
    Original owner here...no notice in the mail yet. ;Really
  11. fx4wannabe
    fx4wannabe Full Access Member
    35
    1,107
    Jul 3, 2006
    Chattanooga, TN
    I had this done on my F150. They had a couple huge lawsuits with peoples houses burning down when there truck caught fire in the garage. So thtas why they are fixing the switches.
  12. motox tech
    506
    Aug 5, 2009
    granby, co
    The recall # is 09S09. You should be able to call your dealership and give them your vin# to see if you qualify? Doesnt really say you need to have letter present, but I could be wrong!
  13. fx4wannabe
    35
    1,107
    Jul 3, 2006
    Chattanooga, TN
    I didn't have a letter when I got mine done. I don't remember if I got one or not.
  14. Diesel Max
    Diesel Max 93 F-250 4X4 - 7.3
    518
    Aug 14, 2009
    New Mexico
  15. Ironman03R
    Ironman03R Full Access Member
    33
    1,954
    Jan 8, 2006
    Risingsun, OH (NW OH)
    I got mine the other day, no time to take it in for awhile though...
Share This Page
