tbrumm
So, if this part were installed and the RABS valve removed, what needs to be done to "fool" the RABS module into thinking the sytem is still operating normally? Or can the RABS module simply be disconnected once the RABS valve is replaced with this part? Or does the RABS module have to still be operational so that the RABS sensor in the rear end will continue to function properly for inoput to the E4OD? I have no idea if this is all tied togther electronically or not. Won't the ABS light be on all the time? Or is as simple as pulling out the ABS light bulb? Thanks to Towcat for posting this. The RABS doesn't work all that great to begin with, and when the valve goes bad, I sure don't want to replace it.
