billyboyr66
like title says I have a tractor project starting and I'm putting a powerstroke on the old girl. I already have the tractor, and the almost complete powerstroke engine.
What I'm hoping for here is a couple answers to some questions I have.
In order to make the psd drive the tractors original transmission all I need is a bellhousing to house the clutch and hold the starter. Then I will fab a driveshaft to go from the clutch to the tractors trans input (shaft driven).
I have found a mid 80's aluminum t19 diesel bellhousing from 6.9 idi Will it bolt up to powerstroke? If so what starter will bolt up and mesh with psd flywheel without to much hassle?
I'm going to look at idi bellhousing today and I'm taking the powerstrokes thin dust shield to see if the bolt pattern is the same.
