Alright alright.
So small progress on a few fronts. First, I pulled the metal plate that the voltage regulator and vacuum switch lives on off the parts truck. Stripped everything off it, sand blasted, primed and painted it.
This will be where the new electrical stuff, fuel pump and hopefully electric vacuum pump.
While the paint was drying, I decided to stick the down pipe on with the new clamp. It seems to fit. I dug out the crossover pipe and made sure it would fit. I was worried about it clearing the oil feed. Think we are good there.
I pulled the radiator and swapped out the old AC condenser for the new one.
I stuck the top radiator hose on just to see. Bottom line is I think the hood will have to go on before I know if I'm screwed with the IC pipes or not. At a minimum the fenders so I can eyeball it.
I dug out the cable and lugs for the battery cables. I thought I bought some 3/0 for the starter but it's all 2/0. Guess we will give it a go. Worst case since it's all stud terminals now, I replace that section. The starter cable will only be about 3 feet long because the battery is under the passenger door.
I also flipped the clutch slave over after coming to the realization that I would never get it to bleed up side down. [emoji21]
Figured out that I could bleed it by myself by holding the clutch pedal in from outside the fire wall. With the crossover pipe off, the bleeder is right there. The wire harness hole let me run a strap in to the pedal.
Worked okay. I've got a pedal now. Not sure how good it is but it's way better than I had before. It snaps back pretty quick.
So a lot of little things.
