So I actually got the headliner material tonight but was instantly disappointed. Here is the material I got along with the samples.
Looks like the one on the right. Problem is I ordered the one in the middle. Not real happy there. Why send samples if you are going to screw up the pick? I hope the carpets are right. They come tomorrow.
In the mean time, I pulled the overhead and headliner out to get back on the wiring. I struggled with how to do the hot wire for the gauges and switches. After going over the diagrams I realized there was a key on and acc on wire running among other things power to the wipers. So I pulled the wiper headlight switch out and checked it. Sure enough.
Black with green tracer. Note, if you have wiper delay, it is a module that plugs in line between the non-delay plug and wiper switch. That would make it real easy to add if you wanted to. Anyway, I tapped the wire before the delay module so now I'll have power to accessory switches with truck running or on accessory. I pulled the last strands of wire and then put the wiper switch back in. That's where I'm at for tonight.
