Weber Auto
Maybe someone else has ran into this problem with the oil temp @229 deg and the coolant temp is @189 deg. I changed the oil cooler and no change in oil temp, i use a ford oil filter, i flushed the block and drained it, coolant was fine comming out of the sides of the block at the drain plugs, checked for cavitation behind the water pump and that was fine, installed a new water pump and my oil temp is the same. I have a EGR deletion on this engine, i believe its a sinester kit. The truck will not start after its shut down at operating temp but after 20 to 30 minutes it will start, the oil pressure is to low to fire the injectors so i know the oil temp is taking out the O rings on the oil rails. Have a great Holiday and a Happy New Year
