oil leaking by starter?
Discussion in '6.9L IH & 7.3L IDI Diesels' started by 93fordturbo, Nov 18, 2010.
  1. 93fordturbo
    93fordturbo Full Access Member
    610
    Aug 15, 2010
    La Crosse, Wi
    I have some oil leaking by the starter. It would be on the side farthest towards the front and it looks like its leaking by where my tranny bolts up to. After about an hour and a half of sitting, i got about the size of a baseball spot of oil. What you think?
  2. Agnem
    Agnem Using the Force! Staff Member Supporting Member
    54
    16,966
    46
    It's either gonna be from the turbo area or a leaky headgasket. My bet is the former based on your description. Best bet is to get the engine all clean and then start looking around with a mirror.
  3. 93fordturbo
    610
    Aug 15, 2010
    La Crosse, Wi
    Where would it leak from the turbo, im not familiar with turbos so where could i look by the turbo?
  4. icanfixall
    icanfixall Official GMM hand model
    24,892
    81
    Any fuel leak on top of the motor will wash the dirt off into the valley pan under the intake manifold. That has a drain way in the back. It emptys right on top of the bellhousing to trans joint. Then it drips down off the starter. You migh look around on top of the motor and the injection pump. Look for wet injectors or injection pump...
  5. snaponprofile
    snaponprofile Full Access Member
    943
    Mar 31, 2011
    NY
    Oh, what ever happened 93fordturbo? I have a similar problem with no solution yet.
  6. RLDSL
    RLDSL Diesel fuel abuser
    7,701
    Dec 14, 2005
    Arkansas
    By the starter , that could also be the dipstick tube.
  7. RANOVRU
    RANOVRU Full Access Member
    438
    Apr 11, 2011
    Virginia
    This is like shootin craps lol.
    It could be anything. I know Ive sat looking at oil leaks for a looong while before tracking them down. You just need to look harder/longer.
  8. Kevin 007
    Kevin 007 Full-floater
    1,564
    Mar 14, 2011
    Nelson BC Canada
    Have you confirmed that it aint a valve cover gasket?
    Mine is doing the same thing on the other side of the block. I have replaced the VC gaskets just to eliminat that possibility.
  9. snaponprofile
    943
    Mar 31, 2011
    NY
    I maybe, I don't know how a VC could be leaking out so fast though??
  10. RLDSL
    7,701
    Dec 14, 2005
    Arkansas
    Best bet is to get a couple of bottles of UV dye for oil and run it in with the engine oil for a little bit, then run the truck up on ramps and go after it with a UV light and glasses like used for detecting AC leaks ( most parts stores will carry a cheap set for around $15-18) and the leak will leave a bright yellow glowing trail leading straight to the point of origin, no more guesswork required ;Sweet
  11. CaptTom
    CaptTom Full Access Member
    725
    May 22, 2009
    ca
    Talk about taking the fun out of the hunt! :rotflmao
    Great idea though. They have that stuff that's oil compatible?? Only seen it for AC, but then again, I never looked for it either. :dunno
  12. '94IDITurbo7.3
    '94IDITurbo7.3 HAMMER DOWN!
    5,353
    Mar 29, 2011
    Fowlerville Michigan
    take the fun out of it.....yes, but the coolness factor is off the charts:rotflmao:D.
  13. riotwarrior
    riotwarrior Supporting Member Supporting Member
    52
    14,105
    22
    Yes they have it for oil, I have some and it's very useful. Gotta like just looking at a drip and getting to the root of the of the issue in no time!
  14. CaptTom
    725
    May 22, 2009
    ca
    I wonder if I could slip some to my neighbor.... I think he's losing his mind. cookoo
  15. Kevin 007
    1,564
    Mar 14, 2011
    Nelson BC Canada
    Is it possible for a head gasket to leak that much oil? Without looking at it I would still bet either a VC or head gasket. Unlikely for the valley to start leaking out of nowhere.
    For your sake and my own I hope it aint the head gasket!
Share This Page
