Oil Leak? on Cold Start
Discussion in '7.3L Powerstroke Diesels' started by rmckee242, Feb 19, 2010.
  1. rmckee242
    rmckee242 Registered User
    47
    Dec 12, 2007
    North Carolina
    My 97 dually had been parked for several days while I was attending a class. Had been really cold during the day and in the teens at night. Started her up when I got ready to leave and it puked oil out the drivers side of the engine somewhere. Didn't crawl under to look because only about a cup or two (looked like) ran out. After it had ran a few minutes it stopped. When I shut it down and started back up during the trip home it didn't happen. Only thing that changed is I plug the truck in at home to be easy on cold morning starts and it wasn't plugged in this time. I'm sure something is screwed but what is it? :dunno
  2. hheynow
    hheynow the misanthrope
    6,083
    Mar 23, 2004
    SF Bay Area
    oil cooler o-rings leaking?
  3. rmckee242
    47
    Dec 12, 2007
    North Carolina
    Could bad o-rings leak on a cold start-up. Plugged in at home it has never done that no matter how cold the outside temp is.
  4. LUCKY_LARUE60
    LUCKY_LARUE60 Full Access Member
    463
    Jan 14, 2005
    Oregonia, OH
    Yep, oil cooler O-rings leaking, mine has done the cold leak for over a year unless the outside temp is above 25* or unless it is pluged in. Not a big job to change out the O-rings just messy.
  5. rmckee242
    47
    Dec 12, 2007
    North Carolina
    Looks like I'll be changing mine. Are these parts I need to get ahead of time or standard o-rings?
  6. aaklingler
    aaklingler Registered User
    33
    602
    Jan 9, 2005
    Winfield, PA
    You need to go to Ford and get them, I think there are 2 on each end.
  7. leftcoastjeff
    leftcoastjeff Frankentruck lover
    407
    May 4, 2008
    Monterey, California
    Another one, wow
    Looks like this, I'm pressing the log into the rear header. You can see the other header in the background.
    2 orings on each end, Ford dealer will have them, if they don't, try another Ford dealer.
    [​IMG]
    I can dig up the part#'s for the orings if needed.
    Got the gaskets from Napa.
    This is one of those jobs...........probably 10 ways to do it.
    LCjeff
  8. rmckee242
    47
    Dec 12, 2007
    North Carolina
    No need for the part numbers I'll call my buddy at the local dealership Monday. Got to thinkinking and that explains why that side of my engine appears wet but never drips that much. Got a few miles until my filter change on a first run of Auto Rx. Probably wait until I change the filter and get real messy. Thanks much. Read alot on hear but don't post that much but when I do you guys always give good advise.
  9. rmckee242
    47
    Dec 12, 2007
    North Carolina
    One more thing. Did some research now the question is do I raise the drivers side of the engine or not. I want to remove the entire assembly because I don't want to risk cracking the front cover.
  10. TBigLug
    TBigLug I Miss U Baby Girl
    34
    302
    Mar 3, 2007
    Jackson, MI
    How much do the o-rings run and how big of a job is it to change them? My uncle's truck does the same thing but to the extreme. Pukes out about a quart every time you cold start it but then doesn't leak at all once it warms up. I topped off the oil after it warmed up this morning, drove it 1,400 miles today and didn't leak at all after it warmed up. Still full after the end of the trip. Stockbridge, MI to Lebanon, MO and back.
Share This Page
