Mar 3, 2017 #16 I idiwelder Registered User Joined Dec 8, 2016 Posts 15 Reaction score 2 Location Missouri I got the oc out now and apart You must be registered for see images attach You must be registered for see images attach You must be registered for see images attach Sent from my iPhone using Tapatalk
Mar 3, 2017 #17 I idiwelder Registered User Joined Dec 8, 2016 Posts 15 Reaction score 2 Location Missouri I took a box knife a slowly shaved away metal till I got the regulator out and it looks like the plunger is in there pretty good You must be registered for see images attach You must be registered for see images attach Sent from my iPhone using Tapatalk
Mar 3, 2017 #18 I idiwelder Registered User Joined Dec 8, 2016 Posts 15 Reaction score 2 Location Missouri Just in case anyone is curious the measurements on the pressure regulating valve spring are .04" thick wire 1.5" long .42" wide Sent from my iPhone using Tapatalk
Mar 3, 2017 #19 typ4 Supporting Member Supporting Member Joined Dec 24, 2005 Posts 9,100 Reaction score 1,383 Location Newberg,OR That stuck plunger is your problem. If you can wait till I get home I'll have orings for you.
