I recently purchased a 1992 f250 with a 7.3 to swap the transmission into my crew cab. Due to sh*t i cant work on pulling the trans so i decided to try to get it to start and drive it till i have time to pull the trans. I put a battery in it and tested the voltage of the battery, power going into the starter relay and power in the fuse box inside the cab. The headlights/taillights work but nothing else inside works (dash lights, ignition, dome lights, horn, etc) what could be causing this problem?? any help is greatly appreciated and thank you in advance for your help.
