I'd definitely look into this.
In my '93, I ran into the clutch slipping on me on a trip hauling a trailer. It just started to get slowly worse.
Something must have not been adjusted quite right, because I just yanked out the rubber stopper for the clutch pedal on the "up" side. The problem got better over the next few hours, and while my clutch still needs to be replaced... it went from 'immediate clutch replacement' to 'eh, it'll last for another couple of years if I don't try to make it slip'. (and that's with a stock 11" DMF holding 250RWHP/460+ft-lbs of torque, which is probably at the limit anyway).
So I'd definitely be making sure that the clutch master cylinder fully disengages, so it doesn't "pump up" and reduce the force on the clutch.
Remember also that these clutches always have /some/ force on the throwout bearing(so it's always spinning) from a spring inside the slave cylinder, so...
