Mitchell Overdrive......
Discussion in '6.9L IH & 7.3L IDI Diesels' started by icanfixall, Mar 29, 2011.
  1. icanfixall
    icanfixall Official GMM hand model
    24,892
    81
  2. marblecrusher
    marblecrusher Full Access Member
    470
    May 26, 2010
    Van Alstyne, TX
    wow now thats awesome. I bet that gets snatched up pretty quick!
    -Jordan-
  3. Fordsandguns
    Fordsandguns Fords Rule
    2,188
    Jun 5, 2007
    Eastland Tx
    That would be awesome! Too bad it's so far away. The buy it now isn't too bad either.
  4. towcat
    towcat Administrator Staff Member
    17,005
    119
    I have one of those units. mounting it is the issue. there's very little space to hide that monster.:eek:
  5. david85
    david85 Full Access Member
    3,516
    8
    Feb 21, 2008
    Campbell River, B.C.
    Finally, an auxiliary overdrive with a REAL overdrive ratio - 27%;Sweet
    So why wouldn't it work with autos?
  6. towcat
    17,005
    119
    prolly because there is no automatic disengage like a GV has with the control box. there is items like the Muncie "electric shift" for PTO's that can be adapted to the Mitchell, but it takes money for R&D that they prolly don't have. for all intents and purposes, it is a "lightweight" brownie box.
  7. Diesel JD
    Diesel JD Full Access Member
    35
    6,148
    Feb 7, 2006
    Gainesville, FL
    I thought I've heard of people using a brownie box behind a C6 or Dodge 727 auto. I guess it could be tricky but couldn't you just shift the Mitchell/Brownie if you were sitting still or float the gears? Or does this risk tearing something up? I guess it's a big project, but probably easier than the brownie which was never intended to go in our trucks to begin with. At least this one might be since it was already in an OBS pickup.
  8. The Warden
    The Warden MiB Impersonator Supporting Member
    36
    7,337
    Fog Bless Pacifica (CA)
    I could be mistaken on this, but I think the Mitchell is meant to be a shift-on-the-fly. I met a guy who had one behind a C6 in an F-350 crew-cab dualie, and he was very happy with the setup. Unfortunately, he ended up going the Dodge/Cummins route many moons ago...
    If I had a 2 wheel drive, I'd be very interested in that unit...
  9. Goofyexponent
    Goofyexponent Mentally Unstable..
    33
    4,567
    Jan 7, 2009
    Halifax / Nova Scotia
    What I wouldn't give for a 5 speed, IDI turbo, cowl induction, intercooled, 4.10 spun rearend WITH one of these boxes slapped in between the transmission and transfer case....that way I could use 4x4 if needed.
  10. GenLightening
    GenLightening Yeah, it's a CHEVY!
    1,917
    Oct 24, 2006
    Pukalani, Hawaii
    I think with newer trucks, that have the speedo sensor in the rear end and endless computers to run everything, it would confuse the shifting programs. Should work with our generations.
    I think it would fit the Chevy.....
  11. icanfixall
    24,892
    81
    The statement about the Brownie not really being fit to our rigs... Nope not so... I worked on Roberts Brownie setup when he was out here on the west coast. Now thats a nice clean setup right there. The way he designed and installed it makes it look like a factory option plus.... The 15 forward choices in gears is out of this world for choices.:sly
  12. jam0o0
    jam0o0 Full Access Member
    370
    Mar 25, 2010
    houston, tx
    i want. darn the $200 shipping though. for $500 it's still a good deal i think.
  13. GenLightening
    1,917
    Oct 24, 2006
    Pukalani, Hawaii
    Hmmm, what to do? I do have some cash coming in that the wife doesn't know about.....
  14. towcat
    17,005
    119
    buy it and take a trip to the coast to pick it up;Sweet
    unlike a GV, it is impossible to blow up a Mitchell.
  15. The Warden
    36
    7,337
    Do you have 4.10's or 3.54's?
    If you have 4.10's, then I'd say go for it, from a technical standpoint.
    I'm not sure how much trouble you'd get in with SWMBO when (not if) she finds out, though...are you "just" risking castration, or is there a chance of outright homicide?
Share This Page
