Nickbf2504x4
ATV Racr-IDI Driver
I just bought an ATS non wastegated turbo(rectangular filter housing) and the seller said it was complete but there are no instructions... any photos or instructions would be greatly appreciated thanks
there should be a fitting on the top of the turbo for the line to connect to. You should be able to find it at any hardware store. I got creative since I have plans to put a pressure accumulator tank for cooling down the turbo after shutdown.So, I had a block machined for a larger fitting on the top of the turbo. Also, I have a wastegated ATS on my truck so I can't be much help on the "missing" parts and from my conversation with ATS, they aren't doing much in the way of supporting the IDI stuff anymore. They do have parts for the wastegated unit but the non-wastegated doesn't have a PDF file on www.atsdiesel.com . You also might want to PM "the warden" since he has a running non-wastegated ATS on his truck. he might be able to answer most of your parts location question. My experience with the wastegated unit is pretty good. the location of the parts is mechanic friendly outside of the uppipe assy which didn't want to seperate. Wound up lifting the body to pull the motor. Steel block on the top of the turbo can be seen on the pic below.Nickbf2504x4 said:thanks for the advice and inspiration but im missing a few pieces backoff that wily seller)...i have the turbo (obviously) and there is an elbow on it that a braided steel oil line attaches to...my question is where is the oil supplied to the other end of this line? is this an ATS part or can i get it from autozone? again
L.Wilkinson said:I used to install the ATS non waste gated kits. The oil supply fitting you are in need of (I replied to your post over on the TDS as well!) is a 1/8"NPT 90 degree elbow, #4 JIC male flare for the braid supply hose to connect to. The small square head pipe plug is adjacent to the oil filter, visible from below on the driver side and can be tight to remove. I don't have any documents like the Warden, but can still remember just about every aspect of the installation, got them down to about 6 hours including full exhaust and gauges into the cab.
Lorne
