Hydroboost reseal tutorial (long)
Status
Not open for further replies.
ifrythings
BC
Disclaimer: Like anything on the internet that you read or follow it is at your own risk, Oilburners nor I will be responsible if you screw up, it is up to your discretion if your able to perform this job with your skill level and tools.
If your in my situation where your hydroboost is leaking from the power piston and running out from between it and the master cylinder and a reman unit is $500+ and tax on top of it or you got a junkyard unit (like I did) and want to freshen it up for around $50, read on.
This guide should be applicable for all hydroboost units, not just Ford as all units seem to be the same design with a few little odds and ends changed here and there.
Note: If your accumulator is loose (the blue or gold canister on the side of the unit) I have no idea where you can get new ones but you can rob one off of any unit in the junkyard thats tight on it's unit. Blue and gold have different pressures from my research, so only use blue in blue applications and gold in gold applications. (Mine was toast and I stoled one off a chevy truck somewhere in the 2000 ish year range)
I had a relatively stiff peddle which felt like manual brakes but with balls when you pushed hard enough on it, the leaking power piston was the cause of this as now it feels closer to how vacuum assists feels and no more leaks!
Note2: If your brake peddle sucks right to the floor when you start your truck up and you HAVEN'T taken the unit apart yet, this most likely will NOT fix it. If you did take it apart and it worked properly before but doesn't now, you more then likely don't have the lever assembly hooked up to the spool valve properly or at all.
The parts:
I order: NEW COMPLETE HYDRO BOOSTER HYDRO-BOOST REPAIR REBUILD KIT 2771004 ALL MODELS There are other cheaper kits out there but they only come with seals, no spring retainer or check valves and other non used parts for this unit.
A clean well lit work space is essential for this repair, no working on the lawn, you'll loose everything. A bench vise is recommended but not absolutely required, a big c-clamp will work also to remove the accumulator, brake clean or solvent to clean the parts and your basic wrenches and picks are all you need.
To begin, pump your break peddle 5 to 6 times to discharge the accumulator, place some rags under the booster and the power steering pump.
You should be looking at this now:
Now take a 9/16" or 14mm wrench or socket and remove the 3 nuts holding the master cylinder on (the left stud has 2 nuts on it, one holds a bracket holding the brake lines, you may or may not have this)
Nuts removed, master cylinder starting to separate.
Pull the master cylinder away and set it out of your way without bending the lines. ( you can see the relief in the boost thats full of atf)
Reference pic, nothing to do here.
Now disconnect the two high pressure lines using line wrenches, one is 5/8" and the other is 11/16" and the low pressure return line from the booster. The remaining fluid in the low pressure line drained back into the power steering pump on my truck and over filled it, it may not do this on yours.
Now heading into the cab, you'll have 4 nuts to remove on the firewall, they are 9/16" or 14mm
Now looking at your break switch, remove the red clip and slide everything off to the left, you can do this before removing the last nut on the firewall. (yes I know the brake switch is upside down in this pic, I did put it on correctly when reassembled)
Remove the unit from the truck and place it port side down in something suitable to drain the remaining fluid, theres a fair amount left inside.
Placing it top end up you can remove the lower boot retainer strap and the boot if it's flexible enough.
Now comes the fun part, according to the instructions this is a stake pedal rod that is non serviceable and unit replacement is the only
alternative, that does not vibe in my books so I used a 3/8" extension and some sockets stacked to make a leaver through the eyelet end to pull it out of the stake (sorry no pic of the setup) If you can not get the rod off it just means you can't replace the input shaft seals which if their not leaking and don't get banged up/cut while you do everything else you probably be alright.
Rod removed.
You do NOT need to do these next few steps as removing the mounting plate is not necessary or needed unless your swapping plates or making your own custom plate.
Remove snap ring.
Using a hammer pound out 2 of the studs to make room for your wrench.
Crescent wrench removing nut with serrations on the bottom, this is torque to 100 ft-lbs so it's tight.
What you should be left with now.
Now if you didn't remove the mounting plate, continue on from here.
Removed parts in line up of removal.
ifrythings
BC
Now were going to remove the accumulator, put it in a vise or c-clamp and tighten it down snug, DO NOT crush it, it's under high pressure, what your doing here is pushing the casing in to remove pressure on the retaining clip. The accumulator is a sealed unit thats non user serviceable and stays together as an assembly.
Using a punch, push the clip down and use a pick to draw it out.
Clip removed, you can now take the unit out of your vice or c-clamp, do not drop the accumulator it will want to fall off so hold on to it.
Pull the accumulator off and let the extra fluid drain out. Then put the accumulator aside for now.
Now the kit comes with a new spring retainer so you can bend this one up to remove it but don't wreck the black rubber center part, it doesn't come with that. You can remove it without bending it, thats what I did, just push it cockeyed and work it out, careful it's under spring pressure so don't get shot in the face by it.
Spring clip removed.
Now remove the spring.
And the pushrod.
Now using a 3/8" wrench or socket remove the 5 housing bolts.
Pull the back side off and you should be left like this.
Now if you were able to remove the input shaft push rod you can now remove the power piston assembly and spool valve, DO NOT scratch the spool valve or sealing surface on the power piston.
Parts removed.
Remove and toss the old housing seal.
Now we are going to remove the power piston seal, as you mite be able to see on mine, the seal is almost level with the case, it has no tension left on the power piston.
Using a pick, pry out the old seal, don't scratch the bore!
Using a 7/16" wrench remove the return line fitting.
ifrythings
BC
And it's o-ring.
Now we are going to remove the accumulator check valve assembly.
Using needle nose pliers or a pick pull out the check valve case.
Remove the little pin.
And using a needle remove the other part of the check valve assembly.
And last is the o-ring at the very bottom thats going to be rock hard.
The check valve parts laying in order from top to bottom on how they were removed.
Last part to remove is the spool valve plug, push it in a ways to allow room for you to pry out the retaining clip, don't loose the clip the kit doesn't come with the right size replacement. (this clip can be stubborn to remove)
And spool valve plug and clip removed.
That covers the disassembly of the booster, take sometime and clean everything up before reassembling.
Skip this step if you didn't remove the input rod
Starting off remove the old seals from the input shaft, I used needle nose pliers to pull the edge of the seal until it broke off the shaft, do this for both.
Note: the kit has 3 different size input shaft seals, we need the middle size for are booster.
Using a piece of packaging plastic cut big enough to fit around the end and tapper, lube up your new seals with atf or ps fluid and your plastic seal installer and slide the first seal on into the first grove, then do the second one into the farther grove, lip side TOWARDS the power piston.
Both seals installed, you can see both seal lips pointing down, toward the pressure side, if you put these on backwards you'll have ps fluild all over your feet in the cab.
Picture for reference, do not install yet.
Now were going to install the power piston seal, the kit comes with 2 sizes, we need the bigger one of the two. Lube up the new seal and the bore where the seal sits, you have to start with one end first and slowly coax it into place, be gentle as you don't want any tears at this point. NOTE: lip side pointing AWAY from the master cylinder.
Seal installed and you can see how much more this seal sticks out compared to the old one.
ifrythings
BC
Now time to reinstall the accumulator check valve assembly, start with the beveled seal, bevel up towards you, lube and install.
And now the new yellow piece of the check valve. It just sits onto of the seal.
This picture shows you which way you install the little pin into the check valve (yes I'm holding everything upside down for the picture)
Lube up the o-ring and put it into the case. You should be left with the solid end of the pin facing up and the shaped end against the yellow piece.
Make sure the spool valve is super clean and same goes for it's bore, put a coat of oil on both and test fit, if it slides in nice and gentle your good to proceed, if it sticks or is ruff, remove, reclean and try again.
Now to install the power piston assembly, lube up the seal in the bore that you put in earlier and the power piston, slide the piston in till it touches the seal, put a lite amount of pressure on it while you either use your finger or a plastic tool to gently push the lip around the piston on the back side of the booster where the master cylinder goes, if you just ram it in there you'll either roll the seal or cut it up and everything up till now is wasted, go slow and be gentle! (sorry no pic, not enough room)
After you get the piston in, pull the spool valve out and engage it with the lever on input rod.
Push everything down.
Make sure your input shaft is lubed and it's bore, put the new case seal (the figure 8 seal) into the front half, you can use one finger to hold the power piston back in it's bore so you can have the back housing upside down and slide it into the front half, this makes keeping the case seal in place a breeze and just bolt it together (20ft-lbs for the case bolts).
Now put the spring into the back of the spool valve (I believe if you forget this spring the pedal will suck down to the floor right away or not come back after the first application), put a new o-ring on the spool valve plug and put a small dab of grease on the o-ring, I tried oil but it seemed to just want to cut the o-ring so I ditched that idea and used just what ever grease i had around, your using so little it won't hurt anything.
Using your punch from earlier, use it to help hold the plug in the bore as you put the snap ring back in, DO NOT hammer the plug in, if it's too tight you either don't have it lube enough, the bore where the seal has to slide over has rust build up or you got the wrong o-ring, a medium push and it should slide right in. (Note: this clip is also stubborn to go back in, an extra hand comes in handy)
Put the push rod back in.
And the spring.
And lastly the spring retainer, legs up.
Try to get all the legs under the ledge.
Now put a new o-ring on the accumulator and oil it and the case up, slide the retaining ring onto the accumulator and put it into your vice or c-clamp and snug it down, DO NOT crush it!
ifrythings
BC
Position the clip so the gap is AWAY from the pin hole so you can get it out next time. Using a small flat head or picks, push the clip in all the way till it clicks or you can see it fully seated.
Put a new o-ring on the return fitting and tighten it down snug.
Skip this if you didn't remove the mounting plate.
Place the mounting plate back onto the front lining the key up with the key way, tighten the nut down to 100Ft-lbs or very tight, then using a socket and one of the mounting nuts as a puller, pull the two studs back into place.
Lastly position the output rod on a block of would and tap the input rod back into staked pocket, I used side cutters (wire snips) to pinch the stake back down so the rod can't get pulled out by the brake pedal being pulled on. Install the boot and using a zap-strap or equivalent to hold the boot on
All thats left is to reinstall in the reverse of removal. Make sure you have the relieved side of the push rod against the brake pedal and the open ear of the brake switch goes toward the brake pedal, if you have it the other way you'll have the rod misaligned with the booster and excessive pedal effort will result, if the brake switch is on upside down, your brake lights will be stuck on. you should now be back to this point.
Last thing is to bleed it.
1 Fill Power steering reservoir
2 Crank engine for several revolutions (do not allow engine to start, unplug power feed to injection pump)
3 Check reservoir level. Add fluid if necessary.
4 Start engine. Turn steering wheel to left stop, then right stop.
5 Shut off engine and discharge accumulator. Depress pedal 4 to 5 times
6 Repeat step 4
7 If fluid is foaming, shut engine off and wait for one hour.
8 Repeat step 4
9 Check reservoir. Add fluid if necessary.
Hopefully if you did everything right you should have a leak free booster and possibly even better pedal feel.
Happy wrenching!
Dave.
laserjock
Almost there...
This is great and definitely tech article worthy. The last few pics are not showing up though.
Never mind. There they are. Must have been a computer problem.
First a HUGE Thank YOU! You have taken the mystery out of the sacred booster! It actually is not that difficult apparently to re-seal.
Absolutely fantastic write up, definitely needs to be in the tech article section.
Great pictures, and clear instructions to the point any 10th grade auto shop kid could probably accomplish this!
Again Thanks for such a fantastic write up.
EDIT
Just did evilbay search, and a PS PUMP rebuild kit is bout 20 bucks, and a reseal for PS BOX seems bout same, as such, in for penny might want to consider at the least a redux of pump, and flush the box when done...or do the box too, then all are saweet with new fluid.
laserjock
Almost there...
So what is the recommended fluid? I've read ps and Atf. I'm installing mine soon I hope.
LCAM-01XA
my very own hell
A little trick for if your input shaft seals ARE leaking into the cab but you cannot separate the pushrod from the shaft. You disassemble the unit as shown, and you pull the shaft out of the rear housing as far as the rod will allow it - the two cup seals should be exposed by this point giving you access for repair. Now here's where an assortment of o-rings comes very handy - look through what you have and find a size that would fit well inside the little cavity of the cup seal, the idea is for it to fit nice in there but push the lip of the seal out some. Now cut the o-ring you selected in ONE spot, and snake it into the cup seal. Lubricate the cup seal and the input shaft bore in the rear housing, and test fit your creation - it should slide in nice and tight with moderate force - if it kinda just drops right in then you didn't bump the cup seal lip enough to make it seal well and so you need a thicker o-ring for the job, OTOH if it's fighting you hard that means you made the seal too fat so you need to drop down to a thinner o-ring. If you find an o-ring thickness that works but the diameter is too large, no worries - remember we cut the o-ring to snake it in there, well if the diameter is too large just cut a portion of the o-ring off so that when looped back to form a ring it will be of smaller diameter. It takes some trial and error but it's very doable. Once you got it all figured out, make another o-ring like that, cause you got two cup seals and it would be silly to just do one but not the other.
And before anyone freaks out about cutting the o-rings, realize that it's not the o-rings doing the sealing, it's still the cup seals, the o-rings are there just to fatten them up a bit so they get back to sealing properly - you could achieve the same effect with anything that can be shoved inside the cup seal cavity, however o-rings are easy to work with and come in different sizes and being fairly soft rubber can do no damage to the cup seals.
BrandonMag
Dana 50 rebuilder
Oregon east
Another vote for inclusion in the OB Hall of Fame (Tech Articles). ;Sweet
Well written with lots of pics. Very nice job.
ifrythings
BC
Thanks guys, I'm going to get some pics of the brake switch and input rod hooked poperly up to the brake pedal for future inquires.
My owner manual lists Ford Type F, I've used any ATF that is of decient quality and never had any problems, keep in mind if your pump is already making noise there is no hope in making it quiet again, its toast at that point. One thing I always do when I've emptied the PS resivour is to turn the pump by hand till the fluid level stops sinking, this way when you start it up, the resivour wont get sucked dry and wreck the pump, only takes a second of low fluid to make them whine forever.
To LCAM-01XA, thats a good trick to get you by for a bit longer but I don't see it lasting for years, in a pinch for sure do it but on these unit's if you just work at it a bit the input shaft does come out of the crimped/staked pocket.
Status
freqencyheight
